Replacement bathroom fit. Conventional gravity installation.
Static head 2m between water level in CW tank and highest part of bath mixer.
Cold feeds direct from CW storage tank in roof in new 22mm Hep across floor of loft then straight down into bathroom. Take-off for loo first in 15mm then 15mm for WHB finally still in 22 to bath shower mixer.
Hot feed from HW storage cylinder via old (1957) 3/4" steel barrel from tank then under bedroom floor then convert to 22mm Hep in bathroom. 15mm take off for WHB, 2nd 15mm take-off for HW tap in kitchen then to BSM in 22.
Hot flow at kitchen tap excellent (not surprising - good head) old washer tap. Not mixer BTW. Cold in kitchen is direct from mains - separate tap.
Both BSM and new WHB mixer tap are 1/4 turn ceramic disk type rated for min pressure 0.2 bar - so perhaps a tad marginal. Both have U shaped Both fitted with flexi connectors and service valves. WHB is monobloc so 8mm screw fitting into base of tap.
All gate valves / service valves fully open. Both hot and cold cleared for airlocks using w/m connections in kitchen using mains. For cold airlock check used cross flow method hot to cold in BSM.
Flow at both fittings is carp. Haven't measured actual flow rate though. Basin livable with (just). Shower really not good but expected that. Diverter valve operation is via lever operated cam - doesn't require pressure to hold it up. Probably add pump when can afford it. Bath tap flow is appalling though and bath takes eons to fill and that is current problem.
Also although flow rate at bath in both hot and cold approx the same and pressure is same (both from CW storage tank) cold always overrides hot when both fully open on the mixer.
Pressure could be increased by pumping or raising CW tank I guess. 1st a possibility but 2nd rather over the horizon at present.
Any other ideas please as either to cause or solution? I'm fresh out!!
