Hello all,
I live in a maisonette built in 1965. It is part of an estate. I will be installing floating laminate flooring in our lounge and hallway. To prepare I have pulled up the existing carpet and linoleum tiles that were in the hallway. I'm about to tackle the lounge.
I want to install underfloor heating before having the new flooring installed to replace our current night storage heating system. Should I pull up all of the lino tiles in the lounge as well? Or should I install the underfloor heating system on top of the lino tiles? I would of course be putting down 6mm (or 10mm?) insulation boards down first. So: concrete - lino tiles - insulation board - heating system - laminate.
I have verified that the laminate is suitable for underfloor heating. The heating system I am considering does not require a moisture barrier.
Many thanks!
Many thanks!
