Hello,
I live in a 1930's house with a suspended wooden floor. The joist centers are around 360 mm. I say around as they vary slightly from joist to joist. The joists are 4" x 2" and currently have 22 mm floorboards.
My plan is to remove the existing floorboards and put celotex insulation between joists, then install a water underfloor heating system, which would then have a small biscuit mix screed to the top of the joists and then install plywood over this. I was thinking about 18mm WBP, but I am not sure of the best option to take, hence why I am have joined this forum.
The marble tiles are 305 mm x 305 mm x 10 mm.
Any help or alternative options would be appreciated. Looking for the best price to achieve the finished result I require.
Thank you!
Thank you!
