The property is a Victorian terrace dwelling in 9" brick (no cavity), with two rusting cast iron vents at the front, the size of single bricks. The survey said they should be replaced: but on closer inspection the vents are above the internal floor level and only on the outer leaf, so the sub floor is not being ventilated.
I will have to dig down and install new air bricks at the surveyors expense because it was his negligence that missed it.
My question is: do the building regulations give any guidance, or require prior approval of the works?
Blup
Blup
