I've searched and have yet to find a definitive answer to my problem. I am having a new kitchen fitted and have gutted the old one and the dining room, and have had the wall removed between the two to make one large open plan space. I intend to cover the entire floor with laminate.
The old kitchen has a newly laid concrete floor (was previously clay with Victorian quarry tiles), and the dining room has its original floorboards which have been made good and soild.
The question is what I need to do the prepare the floors. The kitchen units and cooker will be installed prior to the laminate going down.
What do I do before the units are installed?
A: Do I do nothing, fitting them over the existing concrete and floorboards, then fit ply or chip and the laminate later.
B: Put down 18mm T&G chip across the whole room, then install units and laminate (if so, will the chip expand because it will be "pinned" in place as there will be units and a range cooker on each side and the weight will not allow it to move?).
C: Put down thin plywood across the whole room (as above, and with the same question about expansion).
D: Something else entirely (if so, what please?).
Many thanks for any help with this, as every book, internet resource and pub expert has a different theory.
