I need to replace one in a rental flat. The one coming out is an Ariston approx 10 years old and although the aperture in the carcass is standard (600 x 570 mm) there is a (40 mm?) PVC water drain pipe and an electric terminal box against the back wall. This was fine, as the oven only occupied 500 mm depth.
So far I haven't found a replacement less than 570 mm deep, which would require moving of the pipe (washing machine drain) which would complicate its fall.
Can anyone suggest an oven to fit? It only needs to be basic.
Many Thanks - braniff
