Hi all, ive acquired an all metal box trailer. Its got higher sides than a normal trailer but they can be folded down.
The sides are locked together by 4 bolts in each corner and you remove these to get the sides down.
At the moment it has 4 bolts and nylon nuts which are a pain to undo and took quite some time earlier to get all 4 out do the positioning and tightness etc.
In order to get the trailer in and out of the gate the sides need to come down and tipped on its side so its something i want to try and make a quick 2 minute job to lower and raise the sides.
What sort if nuts and bolts could i use to make this an easier task than it is at the moment? I was thinking of using wing nuts but not sure if they would unscrew themselves? Was also wondering if there any kind of secure quick release pins that could be used but dont come undone?
