My stairs cut diagonally down through my kitchen and are currently partitioned by a single thickness of plasterboard which has small tiles on it (in the kitchen). It amounts to a triangle about 6 x 6 feet on the short sides. The tiles obviously stiffen the partition but the whole thing is bowed, possibly due to weight of those tiles, so has to come out.
Plasterboard seems to be an inappropriate material for this job as a single thickness would be unsupported except around the three edges of the partition. I don't want to tile the kitchen side either. There would be insufficient space to construct a double skin stud wall partition due to a kitchen door frame.
Is there a way to strengthen plasterboard in an application like this ? Would fire-retardant mdf (red) be a better choice and is it fire-retardant enough to go between the kitchen and stairs? Would two thicknesses of 9.5mm plaster board glued together be strong enough without any support except at the edges of the triangle ?
