So,
Some roofers re-roofed our flat roof some 30 months ago. They removed a felt roof (which had done close to 20 year's service) with an (allegedly) Firestone EDPM rubber roof (turns out it isn't Firestone but something similar).
20th October, Storm Babet happens and the roof leaks. Not the rubber membrane but where the rubber roof meets the gable wall. They fitted a metal trim over the EDPM and then applied some 'gunk' between the trim and the wall (it isn't silicone, I think it is a sort of grey mastic), but they didn't do a terribly good job (given that the storm found all the holes that they'd left in the mastic) and the penetrating water brought down a ceiling inside.
Due to the fact that these guys took their hats and spurs off and hid their horses around the corner before doing the roof, we've not asked them back!
Given that we can't get the roof repaired/replaced before early January, I was wondering if there was a waterproof tape I could use to cover the join between the metal trimand the brickwork - bearing in mind that given the current weather, the bricks are both wet and cold.
In essence, I'm looking for a waterproof tape with adhesive that will work in the cold and stick to wet brickwork!
Such a thing exist?
Thanks inanticipation,
XRD
Such a thing exist?
XRD
