I'm planning on building a shelf spanning over 4 meters & am looking for advice on what material to use. I think I've solved the issue of how to mount the shelf thanks to replies to my question in general questions. A quick run down is that I think i should be able to carry the weight across the span using 250mm/200mm fluted angle brackets fitted every 300-400mm apart with the shelves split into 2 sections of around 2 m.
My question is what type of wood would give the best rigidity? I'm not too concerned about the finish as I plan on finishing it to look like the wall. Would I be best of with blockboard with a finishing strip to the edge or a solid plank of wood? I intend to use the shelf to store magazines & books so the weight will be sustantial: I measured a 200mm high stack of magazines & it came in at 11kg so 55kg per meter.
Cheers
Cheers
