View media item 20541 View media item 20542 View media item 20538Hello
My girlfriend's Dad wants to extend the summer house at the back of the garden to install a W/C (gardens 50m long so a trip to the top and upstairs is a bit inconvenient).
I've done some thinking for the electrics and was wondering if you could take a look? Sorry about the picture quality, a victim of the forum's compression software...
Basically there's a 40A cartridge fuse in the old fuse box in the house. This feeds the summer house consumer unit via 10mm SWA/T+E. The main incomer at the summer house is 30mA RCD protected.
The main circuits will be as follows:
EDIT:
Note there are separate discussion regarding the building and plumbing works on the other forums.
- Existing B32 mains ring kept as is
New B10 2.5mm route to heaters in wash room/WC fed from FCUs via wall-mounted thermostat
Existing C16 shed sub-main to be kept as is
Existing B6 lighting circuit extended in 1.5mm to lights in wash room/WC with wall switches
Existing B6 garden lighting circuit kept as is
New B32 6mm circuit to in-line water heater located adjacent to/under wash basin.
EDIT:
