I've just bought a Draper sump pump.
Instructions give info on everything except how to connect a pipe up to the outlet.
There's an 1-1/4" spigot on the outlet, so I tried an 1-1/4" lay-flat type hose, but when it's under pressure it's like an iron bar and won't bend (which I need it to do).
I need to put this into a permanent set-up in a cellar, so looking for something a bit flexible for getting around difficult corners.
It about an 8m run, so any suggestions? (Gratefully received).
