I am currently using Sundeala Board to construct a base for a model railway. I have never used this baord before and am unsure about it, the writing on the board states "CONDITION BEFORE USE" what does this mean exactly and how would one do this? As is the case for Hardboard needing to be moistened before laying is this also the case for Sundeala, I ask because the area in which it is to be used will never ever get wet. Secondly, by what method is the best method to fix it? The boards "a total of 9, " will be laid on 9mm plywood which has been fixed to a sub frame, I have tried using spray glue applied to both board and ply, but find on contact the adhesion isn't particulaly great, therefore, would i be better off using screws, " I only ask as the customer would rather I did not use screws preffering another method, if anybody can suggest one" If anyone can help then it really would be appreciated, thank you
