I've got an intermittent problem with my CH where, at the end of a program, the controller seems to close the 2 motorised valves but leaves the pump and boiler running. Normally the boiler, pump and valves all shut off at the same time.
The controller is a sunvic select 207 (12 years old) and , since I'm not a diy'er or electrically qualified, I'm thinking of swapping the controller for a sunvic select 207 xls which I assume is just a newer version.
My question is - will the 207xls physically fit directly onto the existing 207 backplate and do the two controllers use the identical wiring setup?
