I have a Sunvic select 207XL programmer unit on my water heater /boiler.
I can't use both hot water and heating at the same time, they do work independetly though:
That is, if the heating works, and you turn on the hot water, 2 things can happen:
1) The hot water pump DOES starts working BUT the heating gets turned off on it's own (thermostat for heating lamp turns off and pumps for heating also turn off).
2) The heating keeps working, the lights for the hot water show that it works BUT the hot water pump doesn't work.
What's wrong here????
I know all the pumps are working (since they work independently), the boiler works too, must be the Sunvic (might not be setup correctly???)
thanks
thanks
