I am currently using a wireless sunvic room thermostat (very basic one with + and - on display). Since i moved in a couple of years ago i have had nothing but problems with my heating. My boiler is a Vaillant Ecomax and the programmer is a Honeywell (sorry i don't have the model numbers at the moment i am in work stressing about it and need to get the problem sorted!!). my heating system is a traditional one (not a combi) When i set the the room stat to a higher temperature than the room the the central heating does not click on. If i press the test button on the the receiver the heating will come on for a while but then appears to stop (the rads get warm but then go cold again after a while (especially if the hot water is on) - without reaching the desired temperature on the room stat). Does this sound like the stat has broken down or the receiver? I am getting hot water fine, so i guess the boiler is working fine.
I am also thinking that maybe the diverter valve is not working properly, perhaps its not switching over for the heating? does this sound likely?
Any help would be raelly apprecaited - i am getting so fed up with no heating!!
Matt.
Matt.
