SupaJet 210 power shower fault
11 Jul 2006
West Glamorgan
Hi Guys,
Wonder if you can help, was at a friends today changing some pendants and a broken socket and they asked me to take a look at their shower as its not working properly. Its a SupaJet 210 and when switched on it doesnt draw in any cold water just hot water, resulting in a shower you cant stand under as its too hot, turning the temperature adjustment does restrict the flow of the hot water but still the cold water isnt getting through. I tried to remove the cover to check for anything obvious but the outlet pipe on the front is stopping me from doing so and i don't want to pull too hard in case i damage the shower.
I just wondered if any of you guy here can offer me any advice on what the problem may be and also how to get the front cover off :) When its turned on the pump starts up as normal.
If you need any more info just let me know.
Cheers guys
Dan :)
Hi Guys,
Can anyone help me with this one, sorry to be a pain. If nobody can help then i'll tell them to call a plumber.
Any replies would be apreciated.
Cheers guys
Dan :)
I have a similar problem in that my supajet is drawing very little hot water. I just wonder if you had any joy in overcoming your problem.
Yes its all sorted now, they called a plumber who found that another plumber who carried out work in the house a few months earlier had isolated the showers cold water supply but hadn't turned it back on when he had finished.
So basically there wasn't anything wrong with the shower.
Sorry i cant be of any more help.
All the best
Dan
