I assume that the phone is made of plastic so, Removing super glue from plastic surfaces using rubbing alcohol. Dip the tip of a cotton swab in rubbing alcohol. Apply the cotton swab to the glue on plastic surfaces. Once the glue softens, wipe the plastic surface.
