I have very recently purchased a house (Guildford BC) and am looking to do an extension to increase the size of my home. Architects/planners has said that under PP a max of 40%-50% increase in floor are is likely to be allowed ('Scale & Character' in Greenbelt).
Current is c1650 sqft (1400 'original'**) and would like to get to c2250 (+ loft) which equates to +60%. Therefore i would like to use PP and PD to overcome this limit.
I have spoken to a few architects re planning & drawings but think I need more specialist advice. Particularly as I have some concerns over my ability to best use PD.
1. Is there a way to use PD and PP to add 2 storey extension of more that 3m depth. e.g. apply for PP for 4m extension rear (left), build 3m PD extension rear right, then build previously approved 4m extension rear left? [Or if I go the 2-storey PD route am I effectively limited to 3m across the back).
2. How does a square bay window (purple) effect PD? Are the side walls of the bay classed as 'side walls'? (which would invalidate a 2-storey PD extension).
3. I have now discovered that there was a previous extension (1960s) to build up a cat-slide roof into a full room (yellow). How does this impact PD for a 2-storey rear extension? Is the 'original' rear wall taken at ground level, first floor level, or over the full rear section? e.g. does that limit PD at the rear left to just the GF -or- GF & 1F ?
Key: Black=existing. red= planned rear ext. green=planned porch. blue=potential side ext under PD, purple=bay window, yellow=1960s extension (formerly catslide roof), Pink=2-storey PD effected by yellow extension
Existing dimensions: here
Thanks.
Thanks.
