Hello experts
Would you give me advice on the following project?
I'm installing a new electric shower in my bathroom - a Triton "Opal" unit, rated as 10.5kW at 240V.
There was no shower in the bathroom before, so a new supply is needed. The plumber has run a new cold water pipe in copper, and he says that I have to notify my local council because I'll be carrying out the electrical work, with the possible exception of the final connection to the consumer unit.
I've read a lot of your posts on the electrical forum, and I've examined the existing installation, which is as follows:
The service fuse is 100A.
There's some kind of isolator switch between the meter (in a cupboard outside the front door) - it's marked as "63A type 2".
The tails between that switch and the CU are of an unknown (to me) gauge.
The CU is an MK Sentry unit, with two spare channels in it.
The CU contains an RCD rated at 80A, which serves all of the MCBs.
The distance between CU and shower position, via the loft, is 8 metres.
The distance between CU and shower will be within studwork walls for about 5 metres, and then within the loft for 3 metres.
There is supplementary bonding in the bathroom, from bath to hot tap supply to cold tap supply. I believe that the cable size is 4mm².
If I've understand correctly what I've on the forum, the main points about the installation are as follows:
The expected maximum current consumed by the shower will be 45A.
The shower should be supplied by a dedicated circuit, run in unbroken cable.
The new circuit should be protected by a new MCB at the CU, rated at 45A.
The minimum cable size for the shower circuit is 10mm².
My questions are:
(a) Is the MK Sentry a good unit?
(b) What's the minimum size of the cable between the isolator and the CU?
(c) What's the external diameter of 10mm², 16mm² and 25mm² cable, so that I can check the size of cable currently installed.
(d) Is 10mm² cable adequate for the new shower, or should it be 16mm²?
(e) If so, please could you help me understand why?
(f) What "type" of MCB should be used for the new shower circuit?
(g) What are the bonding requirements for the new shower?
(h) Do you have any other advice to give me on this project?
Sorry for my post being so long - I worry about the detail cos I want to make this as safe as houses.
Dunc
My questions are:
Dunc
