Hi all. Help needed asap!!! Sorry for the length of the post
My friend has got a standard brick victorian semi in Manchester area which has the usual single storey flat roof kitchen extension on the back. He is wanting to open up the wall in between the original and extended kitchen which already has a doorway in obviously. He has gone through all the correct channells - good builder, building control, and a structural eng. to do the calcs for the supporting beam for the opening (which is about 2.7m). My question is - if you imagine you are stood in the old kitchen area looking through the doorway into the s.s. kitchen extension, the engineer has specified that the beam must be supported on a 550mm pier on the right hand side "because it is the corner of the original house", but this will ruin the kitchen layout and there is not a 550mm pier there at the moment as the doorway is only 250mm from the external right hand wall, i thought that 150mm was sufficient?? any idea if he could get away with less than 550mm?? Any help massively appreciated as building has currently ground to a halt. many thanx.
Brookster.
Brookster.
