Supporting a long shower hose around an inside corner
22 Jan 2012
Jersey
Hi all,
Due to how we had to fit our new shower in the bath, I have had to use a 1.75m shower hose to get to the shower head, going from the side to the end of the bath.
Struggling on how to support it as it goes around the inside corner though, whilst making it look decent.
Are there any brackets designed for this? Google isn't chucking up anything relevant :(
Cheers!
if you fix it will you have full range off movement from head to toe left and right
if you fix say the first 750mm will you have enough play on the last metre
try sticking it to the wall with gaffa /packing tape to work out how much you can secure and in what position for best results
