Need some ideas on how to achieve fitting an acrylic sheet.
I have a large ‘barn style’ outuilding, on 1 side it consists of 6 “ square post & gallow brackets.
The other side of this building is a fence, which comes up over 2.3 of the open bays.
The bays are open to allow through draught of air, and air come through fence no problem, the issue is the top 1/3rd allow rain to blow in, and because of the dwarf wall, it gets wet inside and stays wet long after rain has gone.
Hopefully this sketch will show what I mean:
http://tinyurl.com/28q5u7g
I don’t want to close off the bays as need air flow (& light) ... thought about putting in an acrylic sheet between the gallows brackets, just to prevent the blow in of rain.
If I sloped this so that the lower edge was clear of upright posts, it should also provide a ‘drip’ to prevent much of the water ingress.
i.e. as in sketch ..
http://tinyurl.com/24jt8r5
Space between each support posts is 6’ ... and there are multiple bays to do.
Assume I use something like 10mm thick Acrylic ... I can easily manufacture side & top edge supports out of wood .... some ½” x ½” either side of ends & top, would provide location slot.
The issue is what to use for bottom support ... i.e. along bottom edge.
6’ is a long span ... what I need is something I can bond to acrylic to provide a drip, and if it is longer than sheet would also provide a fixing point to outer face of posts.
I having been mulling over using aluminium 90 angle section, anybody any better ideas ?
