Detached house, hipped roof. I want to remove the chimney breasts in the ground/first floor rooms as they're no longer used and just take up space. However I'd like to retain the stacks on the roof, as a feature of the property (built around 1880)
Pretty straight forward on a gable end, however on a hipped roof, the stack isn't tied in above the wall plate so would just be balancing on any steelwork. Roof joists runs parallel to the stacks at approx 400mm centres. 2x king post trusses which, I'm told, distribute the load to the external walls, so no internal load bearing walls either.
Is there a tried and tested method of doing this on a hipped roof?
I would be getting a structural engineer to provide any calcs, I just want to be sure I'm not walking into a very expensive job before I instruct them.
