Hello all,
I'm removing a ground floor wall that supports the first floor joists (no wall above). I have regs go ahead, beam size etc is defined via the correct people. It's about a 3m span.
I plan to support the ceiling with 2 acrows per side. What should I use inbetween the acrows to support the rest of the ceiling ? Is one scaffold board on each side of the wall OK ? Or, should I use a wooden beam of particular W x H, cut to the correct length ?
Also, do I just take up the slack with the acrows by feel or is there any science behind how far to wind them up i.e. take up slack + 1 turn ?
I guess the beam should sit fully on, and slightly overhanging each padstone ?
Does the beam sit in contact with the underside of the floor joists or is there any packing required ?
Also, what mix should I use to bed in the pasdstones into the wall at each end ?
What is the correct material to use to box in the beam afterwards ?
Many thanks!!!
P.J.
Many thanks!!!
P.J.
