Hi all,
In the process of opening up a tiny fireplace to fit a small log burner and in doing so found 3 clay pots (approx 1m total) lining the first part of the chimney. The brickwork I removed to open up the fireplace was supporting these pots and although they’re not unstable I think I need to remove them. Would that be the best plan as resupporting them would take up space for the burner?
The chimney will be lined before burner is fitted.
Many thanks in advance
Mrwood
Mrwood
