supporting SWA
14 Sep 2004
there are 4 SWA cable to go up an internal wall, about 5M in height.
4C 25mm², 4C 4mm² (x3)
whats the best way to support them?
cleats or cable tray? also, if using the tray, how do i fix them to the tray? all round band and roofing bolts?
also, does FP200 have to have the glands on or can it just be stripped back?
I would use tray - dont forget to cold coat the cut ends with galvanising tray.
Use cable ties to hold the cables to the tray - use UV stabalised ones for use outdoors.
Space the tray off from the wall using tray brackets, or cut lengths of uni-strut with M6 zebs and gutter bolts.
Space cable ties evenly, and have the 'buckles' all facing the same way, in the same position - there is a nack to getting it looking pukka!
Oversize the tray, leave room for the future. 3 swa cables the same size can be bundled into one cable tie, and allowed to form a 'triangle'.
Go for return flange tray, this is more rigid than the cheap straight edge stuff.
FP200 doesn't need clanding, although if entering an enclosure / trunking / call point etc, TRS glands should be used. To enter the rear of detectors etc, no point.
Older FP200 used to require a furrel to prevent the foil from knicking the inner cores - FP200 gold doesn't require a furrel.
