My daughter has a Suprima 30 in the house she has just bought
which runs for between 5 to 30 minutes before locking out with the red LED flashing. It almost always requires a manual reset each time.
The temperature of the out flow is very hot whether the temperature control on the boiler is set to high or to low. ( I had no thermometer to measure the water temperature but there was no discernable difference between the extremes of temperature control setting )
I suspect the temperature control in the boiler has failed and the over temperature safety cut out is operating to shut the boiler down.
If the temperature control is working then does the Suprima 30 burner modulate by turning off and on or is the flame height reduced when the out flow is at the required temperature ?
Knowing the quality of the PCBs in some boilers I suspect a PCB failure but would prefer to check the thermistor is giving the correct resistance before paying for a new PCB. Where can I find the expected resistance values of the thermistor at various temperatures ?
