Sorry I can't claim to be one of clever ones!
All I know that my sons suprima give intermittent problems over a period of weeks and we examined and tested as much as we could.
The fan and air pressure switch was checked out and found OK.
The HT (high tension) lead is the ignition lead and this was changed on the advice of potterton who claimed it had been the cause of problems.
Whilst this was going on we had a situation where nothing happened and there was no smell of gas to ignite and suspected the gas valve.
A heating engineer confirmed the gas valve had bust and fitted a new one, but this did not stop the intermittent problem.
We was aware from another forum 'plumbing pages' that there were quite a few problems with the pcb. Eventually we decided to change the pcb and found potterton had just introduced a later version with a different part No.
It cost £134 but we could have had the old pcb reconditioned about £48.
However we fitted the pcb and no further problems.
I've dismantled the old gas valve and I noted that when the main gas valve is closed there is still a path for gas to the burner, I assume this may be the initial stage for the pilot light to light prior to the main valve opening.
I recall there was two solinoids, one I tested and found OK the other had gone bust and there was a small hole in the plastic casing which I enlarged until I found the actual break in the coil.
I also examined the old pcb with a magnifyier and found quite a few soldered joints had cracked, these were on the bottom of the terminal posts.
These cracks explain why sometimes it works and sometimes it don't.
Other readers with similar problems have re-soldered the joints with sucess.
I also consider that the heat generated when the boiler does work plays a part in this, making the cracks open more.
Sometimes a faulty coil on a car would operate only while it was cold.
I still feel the pcb could be the culprit, was it the newer version or one he had in stock, check the fan/air pressure switch first.
You can check this out on
www.curzoncare.co.uk, they show the latest version.
