- Joined
- 20 Nov 2008
- Messages
- 1
- Reaction score
- 0
- Country
I have a Suprima 50 which (etc etc)
After reading other users' posts (for which many thanks) I decided to buy
the replacement kit P/N 5111603.
I believe that this kit is badly designed and the fitting instructions are defective.
Earthing. You are told to connect the earth wire from the spark gap to
the earth screw on the control chassis. But this screw is tucked away
inside the chassis and you cannot reach it without first removing the control chassis from the boiler.
Instructions do not mention the need for earth bonding on the gas & water pipes.
Also nothing about keeping wires away from hot metal.
Both the gas valve and the fan have earth terminals; instructions say
"unused". But if these earth wires were needed on the original design, they are surely still needed.
Instructions say that the side cover must be earthed. If this is so, then
the main cover must also be earthed; no provision is made for this.
I filed off the paint under the fixing screw heads.
Gas valve. The wires to this valve end in a so called "molex plug"
(actually a socket). Originally this had 5 terminals: 2 & 4 connected together and 3 = earth. In the new
socket these 3 terminals are all missing. Again, if these were
design, they are surely still needed. The new socket was very loose,
it will fall off if not secured.
Fuse. The top of the control chassis bends over the fuse. The only way
to get at the fuse is to remove the control box from the chassis. Instructions say "3A". Fuse actually
fitted was 4A. Please could anybody tell me the correct rating?
Side panel. When at last I came to refix this, I found that Pot have
moved the socket for the fixing screw about 15mm to one side. Also they have changed the thread.
The old screw is useless and they neither provide a new screw nor tell you what thread it needs to be. ?? 2M ??
Finally: "turn the boiler temperature control to the required
setting". This control is not graduated, how is anybody supposed to know what the required setting is?
IMHO: Label all the sockets on the PCB & their matching plugs.
Unplug all the wires from the PCB & install them into the boiler.
Refit fan & air pressure sensor etc.
Connect all earth wires to a new earth point in an accessible
place (X) on the main chassis.
Put another wire (W) on the earth point of the control chassis.
Insert the control chassis, connect W and X.
The idea is to get all the wires in place before you install the PCB,
so you do not have to install both at once. Also you can then replace
the PCB without having to take the whole boiler to pieces.
