- Joined
- 17 Mar 2020
- Messages
- 36
- Reaction score
- 1
- Country
Hi folks
I have a '98 Suprima 40 and hot water cylinder (3 port valve), after approx 5 mins from cold and selecting hot water I get kettling symptoms (some fizzing/mild clonks) from about 60c to 70s.
I have measured the temperature on the outlet with an infra red thermometer & the thermistor stat is kicking in at 70c. There is approx 6-7c difference on the inlet/outlet also measured near the outlet pipes.. Pump speed changing to 3 (grundfos) helps a little but the issue is still there. The main PCB has been changed in the past also.
I did try x200 last year but it made no real difference. Other than that the boiler works fine.
Any suggestions?
Any suggestions?
