- Joined
- 18 Dec 2004
- Messages
- 1
- Reaction score
- 0
- Country
I have lived in my rented flat for 2 yrs now. I have had endless probs with the CH not running efficiently.
I have a potterton Suprima boiler, which is not working v well. Basically when you turn it on it fires up, (The pilot, and the spark) and it gets the flat hot for, maybe half an hour, then it cuts out, I am left with the red LED flashing, I reset it, and the same thing happens again....and again.
I have wondered about bleeding the rads, but has it actually got anything to do with them? Will it make the boiler work more efficiently? Will it get my water hot?
This happens whether I have it on constant, or on timer.
I have had the landlord call the plumber out on numerous occasions. He thinks there is an electrical wiring fault. The electrician told me it was a plumbing error.
The actual tank and header boiler are up in the loft. They have been looked at, and the setting is now apparently on 2 The plumber reckons the pump is a bit crap, but its doing its job. It makes a bit of a noise but I am used to the noise, doesnt bothre me.
All I know is that I am freezing, and fed up with being constantly fobbed off.
