I'm trying to wire a magnetic surface contact to my texecom 24 alarm system and needed some advice since the packaging was lacking instructions.
The contact has 6 connections from which I guess are:
3-4: the inner two are the tamper connections
2-5: the next outer two are wired together which is effectively the alarm connection (trigger to the magnetic connection).
1-6: wiring through.
I've connected the PIR's using EOL, therefore was planning to follow the exact wiring but for the surface contacts is this correct?
Also the PA switch is very similar so guessing that would be the same?
[/b]
[/b]
