Hoping some one can help.
At the back of the house surface and foul water drains / pipework go directly into a Mains Drain and there are no problems with this. The only note is that the drain access is only just below the surface.
The ground level at the front of the house is roughly 1/2mtr lower!
I need to connect up surface water drainage at the front to the back.
Thought about a possible fall pipe that enters an elbow with an access plate below ground level, then running this underground pipe around and up to the main drain at the back.
This would mean that this drain would remain full of water and up the fall pipe by as much as 1/2mtr. I would have to presumably fit a guard at the gutter to prevent excessive debris getting into the drain and it may mean accessing the elbow and flushing it say once a year to keep it clear.
Would this be an acceptable way to do it or is there a better way?
I don't want the surface water to soak away, the garden is naturally very wet already. The water table is only about 12" to 16" below surface in winter as it is. The building has suffered settlement caused by excessive surface water over its 200yr life already.
Mark
Mark
