Not sure if i'm posting this in the correct section, i'm sure drains come under plumbing but this query seems more of a legal matter I live in one of two semi detached cottages, in open country side, our surface water drains run through agricultural land before discharging in a main watercourse and on to the river.
Recently we have had problems with blocked drains, this has been traced to collapsed drain in the field, it is a six inch perforated land drain pipe which has been almost completely crushed, possibly due to settlement of the ground or possibly due to compaction from heavy machinery, A temporary repair has been carried out although we've been advised the whole length needs replacing, we have been told we are responsible for paying the repair bill and i presume would also be expected to pay for future repair replacement,
My questions are
1. should we be paying if it has been damaged by machinery etc.
2. the drain also carries a large amount of water from another field on the opposite side of the cottages so should it at least be a shared responsibility
3. the drain used to be an open ditch but was piped, filled in and 2 fields made into one, should we of been consulted about the change, an open ditch would of been easy from our point of view to maintain
Any help would be much appreciated thanks
My questions are
