Sometimes when the kitchen light (tube) is turned off, the rcd's on the computer / tv equipment upstairs trip.
Its definately the tube being switched off, as I have a camera pointing at the door where the switch is, and you can actually see the spike interference in the exact frame where the switch is turned off - and at that point the rcd trips just after.
What is the likely cause? Would replacing the switch fix it, or is surge protection needed at the switch or light itself? Could their be a problem with the light/starter?
Our house also keeps blowing light bulbs on a fairly regular basis - its a pain, but electrician could not find anything wrong last time he was here. - could it be the surge from the switch/light that blows bulbs or shortens life?
