I am starting to plan a 3m x 5m side extension which I hope to build myself. A question I have is about the floor. As it's on a slope, and to match existing floor structure, I intend to use a suspended timber floor.
At the top end the ground level is so high that ill struggle to get the bottom of the joists (5 inch joists) 150mm above the ground level, but ill just about manage by digging it out.
My question is, can the DCP go immediately under the level of the joists, otherwise ill struggle to get the DCP 150mm above the ground.
Also, do I need vented bricks on the 3m wall at the top end? if so could these go between the joist rather than under? that's the only way I think I could fit them in.
On another point how regular a distance do you need sleeper walls if im using joist hangers at either end?
Ive added a pic to illustrate my questions.
