- Joined
- 13 May 2011
- Messages
- 2
- Reaction score
- 0
- Country
Hi
Am installing a new ground level suspended floor and need some help on design aspects. I understand that there are some key elements to incoporate in the design but am not sure about some aspects and would appreciate input on these.
Underfloor ventilation. From what I've read cross ventilation is ideal. However, my house design will only allow air bricks on two walls that are not opposite each other. Is this fatal/is there a way to compensate?
Floor ventilation. Is this entirely necessary as it seems a sure way to introduce draught into the house?
Ground moisture barrier. I am not planning a concrete slab and the walls have already been built. Will a black PVC sheeting simply laid on the bare earth soil act as an adequate moisture barrier? Is it fatal if one leaves the bare earth uncovcered?
Insulation. My idea is to lay some insulation between the joists. Does one have to be careful about the type of insulation?
Vapor barrier. In my readings on the topic there has been frequent reference to placing a vapour barrier on top of the insulation, which I assume is on top of the joist and therefore immediately below the wood floor. Is this necessary if one has a moisture barrier on the ground and wouldn't this barrier lead to condensation forming just underneath the wooden floor?
Sub floor. Some articles refer to a sub floor beneath the wood floor. I like the idea as it seems a good way to deal with draught and also to provide an xtra layer of insulation. Has anybody any experience with this? Does this not lead result in condensation?
Draught proofing. What's the best way of draught proofing without introducing condensation?
Anything essential I have not mentioned?
Cheers
Cheers
