Suspended floor with 'dwarf wall'
18 Jul 2004
Devon
I need to install a suspended floor during my garage to dining room conversion.
The floor needs raising by approx 300mm.
I have a soil pipe which needs to remain under the floor.
This is in the way of my prefered span from left to right (the short distance).
I though I could build a small dwarf wall and bed a timber on to this to take the floor joists, however, this additional 2" timber (mortar, block, mortar, DPC, mortar, 2" timber, 6" timber takes my floor that bit too high. I was thinking of ommiting the 2" timber laid flat, and simply sitting the floor joists on a DPC? I am not sure if this is ok.
Or could I build the wall a little higher and bolt a timber to the side of it, or fit joist hangers into this wall?
A crude pic will hopefully explain the above clearer!
Thanks for any input!
You need to give as little more info - what is the span, whats the current floor construction
You also need to think about sub-floor ventilation & insulation
The stack pipe seems to be an unusual feature - running full length of the garage above floor?
Floor is currently a concrete screed, no DPC visable, so assume none.
BCO have ok'ed cross ventilation, and the joists will have insulation as required.
The soil pipe is for a toilet in an adjacent room. The soil pipe is currently not there, as the room has been moved, but is going back.
The window has been replaced with french doors.
http://i27.tinypic.com/2eoa3hc.jpg
Hi, Lec,
you need to be the master of the level not it's slave,
Work down from the FFL and make your brick sub-walls finish at the height you want.
It may mean you have to start with a split course or a course of half bricks on edge laid crosswise along the length of the wall.
I would suggest some air bricks need to be put in the outer wall for venting the wood, however your BI will advise on that.
