We have a suspended timber floor which is hanging off the walls with metal hangers built into the brickwork. The hangers are nailed onto the joists from the sides. To remove a joist you'd have to cut it in pieces and you'd be left with two pieces nailed to the hangers which would be much harder to remove. Any twisting/lateral/ force applied to the joist would probably dislodge the metal hangers which only have a small section inside the brickwork. You may even undermine the structural integrity of the wall, and it is the inner skin which takes a lot of weight from above. To then replace the joists - I am not sure how I'd go about it.
Can anyone please advise me?
