Hey all,
I was hoping someone could clear up some confusion on the construction of suspended timber ground floors.
Does the ground surface underneath *have* to be concreted? If so, what are the depths required?
My builder has put in this floor to our extension, with the correct sized joists cut into the inner block skin, and is today knocking out the morter to put DPC around the ends at my request as they breach the DPC. However at the moment only the new block edge.
The existing house has a solid concrete floor.
He says that concrete isn't needed, I think it is.
Searching hasn't yet brought up any definitive answers, only more confusion.
Stuff like not needing a vapor control layer underneath, but a recommendation for one over the joist tops and insulation under the chipboard floor.
Also, is 50mm kingspan on battens between joists enough?
Mike
Mike
