I've got planning permission for a large two storey extension to my existing property and am currently working through the building regs drawings phase. Part of the extension is a new ensuite with a WC draining to a different external wall than the existing SVP (and family toilet) is located on.
In the plans we originally had the new outlet/branch/svp (or whatever it's officially called) exiting the wall and running around the outside of the extension and joining the original SVP which then leads to the drain. Job done, or so I thought.
My architect has just advised that the new branch/SVP servicing the ensuite will need to run internally (boxed in) and then join the drain directly via a new underground run.
Not wanting to have the boxing present in the new extension I asked why this was the case. Their response was that building control doesn't normally 'like' two external pipe runs to the existing SVP. (All gradients would be honoured in both cases).
I've searched through Document H and have asked my architect to clarify the requirement however they haven't got back to me yet and I'm stressing that we may have to change all the interior design to accomodate this ugly boxing.
Does anyone have experience of similar arguements with building control about having multiple branches/SVPs?
Thanks in advance.
Thanks in advance.
