Not sure if this should be in Building section, but I have the SVP going up one corner in the bathroom. The bathroom is in need of total refit and this SVP really gets in the way. The bathroom is narrow (1650mm) and not very long. I'd like to fit a 1600mm bath/shower across the end where the SVP is, but it's in the way and simply bringing the bath forward means we lose 200mm of valuable space. So I thought of two alternatives (well three really, but the third is the really expensive option).
One idea is to reduce the SVP to 75mm and have the bath (Bette) with a corner cut.
The other idea is to put a bend in the SVP and take it through the wall outside, where it can go up to roof level. I am certain there is enough space under the bath at the head end to accommodate the bends and the T junction.
Can one make the SVP less diameter above any inflows?
Our walls are 500mm stone, so taking through wall is a tough option. making it down to 75mm could ease that.
The third option is taking the whole SVP outside and connecting up to the outside drainage....that's the really expensive option!!
