Im running power to a workshop and aiming on running the swa myself then getting it connected both ends by a pro when they fit the consumer and rcd.
Ive been told I need 10mm swa , how would it be best to bring it in through the wa_ll ? I'm thinking it will not bend and look to good going through the brick . It will have to come in through the garage then through the side of the house to the old fusebox (has mcbs)
Can I put an adaptable box on the outside of the garage and run 10mm twin and earth to that from supply to adaptable box will I need to run a separate 10mm earth to the box to earth the swa , I can't run the swa right to the supply due to location , so it will have to terminate in a box either inside or outside . I could then bring the t and e in to house with the earth where the pro can wire up .
Thanks on advance for any advise
I'm doing something similar at the moment. My builder's solution is to bring it up inside the garage (although mine will be in ducting). Starting from 450mm down you get a nice gentle curve.
The technical details involve 'drilling a great big hole in the garage floor'.
It's a bit unclear but I think the OP is asking about the house end (and house wall). It also sounds from the description that we may be talking of three buildings - house, garage (maybe attached to house?) and workshop. 5watt, can you describe the situation in a bit more detail?
