SWA Size
10 Jul 2006
Cleveland
I've got 2 SWA cables, one is 20mm in diameter the other is 16mm, what size cables are inside them? They are 3 core
Small one could be 4/6 mm².Larger one could be 10/16 mm²
Depends on manufacturer and/or if it's XLPE.(BS 5467 if it's XLPE, should be embossed on the side)
you cannot reliablly determine core size of SWA from overall size, if you new the manufacturer and date of manufacture and had access to the manufacturers specs you could but if you have that level of information you probablly know the size anyway ;). Differences in the packing armour,sheath and for large cables core shape can make considerablly more difference to overall diameter than a couple of steps of core size.
you need to measure the actual copper core area either by comparing against samples of known size or by using a suitable measuring device (verniar caliper or micrometer) to get the diameter and then calculating from there.
