I have a dedicated radial circuit on a 6amp MCB with RCD protection feeding an internal switch by the front door. First switch is for override of a PIR for external door lights and 3soffit lights. Permanent live at first rocker provides a jumper to rocker 2 that provides twin and earth out the side of the back box 70mm to corner then 100mm along (proscribed zones) through wall externally down the wall to 1st adaptable box….this cable needs replacing….Q I want to replace with SWA, can I run this to a adaptable box at point of exit on wall, terminate the armour and outer sheath at this point, run inner core internally to the switch but buried and capped all within proscribed zone so 275mm through wall, 100mm horizontally internally right angle then 70mm to back box. Earthing of SWA would be by fly lead from earthing nut at gland to CPC of 3core of the SWA at first adaptable box….no I’m not an electrician, yes I’m very experienced And yes i know how to terminate SWA I am replacing T&E that is breaking down…thanks in anticipation
