I am terminating 2.5mm2 SWA into a Metalclad spur unit from where it continues in twin and earth. The spur unit has only one earth terminal which is pretty much filled by the SWA earth core, being multi-strand rather than solid core, so room for the other earth or the earth link to the box. Can I:
(i) connect the incoming and outgoing earths together directly via terminal strip, with links from there to the earthing point on the spur unit and the back box? or
(ii) terminate the SWA into its own box, then connect this to the spur unit in twin and earth? or
(iii) find a metalclad spur unit with more or bigger earth terminals (MK??)?
Thanks for help.
Thanks for help.
