My Mums 1980's bungalow has an old 4 way Fuse box so it's about time it was swapped out for a new Consumer Unit.
I've had a look around and there is no earth from the Fuse box to the water pipes or the oil feed pipe for the Oil Central heating so those would need earth straps too.
She had a Smart Electric meter fitted about 2 months ago and the tails come from that to the Fuse box. I'm not sure how thick the tails are but on the assumption they need changing to meet current 25mm thickness regs, is a qualified electrician allowed to cut the security wire/tag on the Smart Meter to get at the terminals and replace with a new wire/tag when done ?
There is also a security wire/tag on the master 100 amp(?) fuse cover going into the Smart meter.
What is the minimum / ideal qualifications I should look for when choosing an electrician for the CU swap .. NICEIC, NAPIT, Part P registered etc as I want an Installation Certificate when the jobs done then I know it's done to regs.
thanks
thanks
