- Joined
- 22 Sep 2015
- Messages
- 34
- Reaction score
- 0
- Country
In the linked photos you can see two radiators, one with a static valve and the other a TRV (with head removed). I need to swap the two valves. The third photo is the lock shield at the bottom of each rad.
What are the correct steps to swap these two joints without hopefully having to flush an entire system? If I undo the nut of the valve at the top, and disconnect the hose, should I expect water to gush out?
Note, I have a district heating system (external heat source feeds my property hot water). I could turn off the HIU and close the 6 inlet/outlet valves to it, but rather not as last time service engineer found it near impossible to open and close them.
