M
marsaday
I have recently put in a velux window. The artificial ceiling is close to the velux and when i went to do the boarding up this week i found the ceiling very damp (the plasterboard basically broke away. So i hacked out all the damp stuff and then went up through the hatch to have a look at the roof space.
Well the timbers next to the chimney breast were very wet. I dont think the chimney is to blame her, but rather the method of roofing the house. It is slate, but underneath they have used polythene (for concrete floors) and then the space between the rafters has been filled with glass insulation.
All i have done is to remove the insulation from between these wet timbers and cut out the polythene sheeting. There is now a good airflow around this chimney area.
Will this be enough ?
